How do you tell if the parts are interchangeable? I like to entertain the idea of putting the crz 16v head on the insight 8v engine. We got 2 spark plugs, but 1 is primary, other secondary so we could loose the right side plug I believe. If the head fits, hope vtec works the same so its a direct replacement.
Plan B is to swap in the whole crz engine. Its a 1.5 vs 1.3. From my experience the Insight uses a lot from the 09 Fit.
