Old 10-10-2014, 03:28 PM   #1187 (permalink)
e*clipse
Permanent Apprentice
I looked into the temp sensor for the MGR.
It looks like it's merely a 50kOhm NTC thermistor, electrically isolated from the motor and case.
In that case, it looks like it would be pretty easy to drive it with the 5V controller supply and a 50kOhm 1% resistor in series. The microcontroller's AtoD converter would see about 2.5V at 25C. I would use the "QEI Index" pin and add this to the resolver driver board. That way all the MGR feedback information could run through this adapter.
Thoughts? Suggestions?
- E*clipse
The Following 3 Users Say Thank You to e*clipse For This Useful Post:
KenC (06-14-2019), MPaulHolmes (10-11-2014), thingstodo (10-11-2014)
