Old 10-11-2014, 09:52 AM   #1190 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Originally Posted by e*clipse View Post
I looked into the temp sensor for the MGR.
It looks like it's merely a 50kOhm NTC thermistor, electrically isolated from the motor and case.
In that case, it looks like it would be pretty easy to drive it with the 5V controller supply and a 50kOhm 1% resistor in series. The microcontroller's AtoD converter would see about 2.5V at 25C. I would use the "QEI Index" pin and add this to the resolver driver board. That way all the MGR feedback information could run through this adapter.
Thoughts? Suggestions?
- E*clipse
That sounds good. We will need to figure out the best arrangement for the A/D conversions. Current1, current2, sin (), cos (), throttle, temp1, temp2. we could always do currents and angles simultaneously, and maybe every 32 times we do current1, throttle, temp1, temp2.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
thingstodo (10-11-2014)
