Old 10-12-2014, 01:00 AM   #3 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by H-Man View Post
Your insight's 90 day MPG is almost as bad as my prizm and I haven't even started the car since installing the airdam. I find this amusing.
Yea this insight had massive problems. Mainly the primary o2 sensor giving the car false information, causing it to use way to much fuel. On top of that, the #2 Cat was clogged, and the exhaust leak wasn't allowing enough exhaust to escape, so there was way to much back pressure. I used to fight the car to keep the SoC from getting completely drained, and I thought the IMA battery was just going bad. Turns out the clogged cat was causing the car to work way, way to hard to move, therefore using more assist. Since I fixed the exhaust, I rarely ever drop below 18/20 SoC bars.
The Following User Says Thank You to Baltothewolf For This Useful Post:
j12piprius (10-12-2014)
