Old 10-12-2014, 12:44 PM   #8 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Originally Posted by Baltothewolf View Post
Yea this insight had massive problems. Mainly the primary o2 sensor giving the car false information, causing it to use way to much fuel. On top of that, the #2 Cat was clogged, and the exhaust leak wasn't allowing enough exhaust to escape, so there was way to much back pressure. I used to fight the car to keep the SoC from getting completely drained, and I thought the IMA battery was just going bad. Turns out the clogged cat was causing the car to work way, way to hard to move, therefore using more assist. Since I fixed the exhaust, I rarely ever drop below 18/20 SoC bars.
How did you discover all of these?
