Hi Alexander, greetings from Nieuwegein, a tram ride away from Utrecht
You know the dump trucks in Utrecht are set to be exempt from the pollution rulings? Council found out their law meant having to replace their entire fleet of dump trucks, so they bent the law instead
Are you keeping a fuel log? Do you have fuel economy instrumentation? Is your car bnew enough for a OBDii device ('96 onwards)?
Are your brakes warmer than they should be after a drive? (mine are! I'll have them cleaned and fixed next week when I switch to winter tires)
