Thread: truck cap aero
Old 10-13-2014, 06:31 PM   #4 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Most aluminum caps have sharp square corners front and back, and don't really "fit" the shape of the vehicle very well. A cab height fiberglass cap which matches the truck's bodywork can actually improve MPG highway. If you have to have a ladder rack, I would either try to get a low profile aerodynamically shaped ladder rack, or get an easily removable one.
An extra height fiberglass cap probably won't be that different than a cab height aluminum one. One has worse CD, the other has more frontal area. Adding a ladder rack to that won't help either.
So basically, aeroshell is best. If you could at all utilize a cab height shell, I would try to make that work. If you don't need the extra capacity every day, but only on occasion, you might even consider getting a small trailer.
