Originally Posted by 30mpg
My lead acid waz dead so I went on Egay and found a 12v 20ah battery designed for alarm systems and I gave it a try. I worked well on my civic and should work on most 4 cylinder cars, They also have a larger one that is 12v 30ah if you live in cold climates. going from a 35lb lead acid to a 14lb AGM should make a small difference in stop and go traffic because less force is required to get the car going again from a dead stopp. $40 Lightweight battery - YouTube
i checked the vid and ebay. prices are as stated. i am interested in how long they live under the heat/cold/vibes. i will be needing a battery soon so would like updates.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
