Old 10-15-2014, 05:16 AM   #15 (permalink)
Madact
Emerald - '97 Honda Civic CXi
90 day: 40.13 mpg (US)
This front bumper from DuraFlex is actually pretty close - except you'd want to blank off most of the scoops, of course
1996-1998 Honda Civic Duraflex JDM Buddy Front Bumper Cover - 1 Piece
Here's a quickly edited mock-up based images on one of the images from the above link. This version has
- Upper grille block
- Generous rectangular stagnation point intake (this is Australia after all, they reckon metro temperatures may hit 45C - 113 Farenheit - this summer. Not including heat island effects.) - not sure if this is the best shape, oval section with rounded edges to avoid separation might be better.
- Bump at the bottom as per "option (f)" ... well, pretty close, anyhow.
- Air curtain intakes - moved back a bit compared to the intakes in the source image, to avoid an unnecessarily long internal vent. Not sure if I'll do this yet.
The Following User Says Thank You to Madact For This Useful Post:
Cd (12-01-2014)
