Originally Posted by e*clipse
Again, I think part of my misunderstanding is directly related to the induction motor. In an induction motor, the rotor's current is proportional to the slip - right? So more slip, then more rotor current, which produces the rotor's field, which interacts with the rotating stator's field to finally produce some torque . . . right?
Current is produced by slip. There must be a difference between the stator rotating field and the rotor speed to generate current in the rotor. The current in the rotor is needed to generate torque.
I'll see if I can find a link to 'howstuffworks.com' ... it does a *MUCH* better job of explaining than I ever could.
As it turns out, explainthatstuff had a better description, in my opinion, and here it is.
http://www.explainthatstuff.com/induction-motors.html
