Old 10-15-2014, 08:42 AM   #5 (permalink)
xavi
I have thought about that, and there are 2 engines with same block, one with 5, other with 6 speeds... but I'm not sure it's compatible, nobody can confirm me 100% sure.
And have to buy a used transmission that may be damaged...
So for the trans issue I decided to stay put for now...
changing tire size isn't an option either, there are no taller tires at that size...
only option is to change the transmission rack at the back, but it won't make a big difference...
The engine has 6.5 hp, but taller gears will loose torq uphill right?
