10-15-2014, 10:01 PM
#268 (permalink)
Changfa diesel + Suzuki
Centurion - '74 FIAT X1/9 Centurion Full Race DNA Last 3: 143.5 mpg (US)
It's total euphoria when the right parts are at hand and they actually fit!
With the correct 20 spline clutch, assembly can now begin.
With clutch properly set and pressure plate torqued to the flywheel it's time to fit the rest together!
The red arrows in the above photo indicate that victory was brief.
For whatever reason, two of the adapter's bolt heads wouldn't clear the new (1980) bellhousing flange. The cast iron is no match for a hand grinder and the violent shower of sparks is swiftly over.....
The area that may need an attitude adjustment is outlined below between the red forks:
Taking into consideration all these little pain in the a$$ tweaks, plus parts finding and delivery time, a steady 60+ hr a week job, and life itself, is it any wonder it takes a very loooong time to get through a tank of fuel to generate any mpg numbers?
Even with some testing/driving since the completion of the transmission swap, Centurion is still not ready for a fill-up..... Clack-clack-clack-clack...
More pulse-n-glide.......
~CrazyJerry
