Old 10-16-2014, 01:38 PM   #19 (permalink)
TedV
Originally Posted by Chrysler kid View Post
Running nitrogen in the tires would cure both problems and tire pressure would remain constant through the temperature changes as it is not as heat sensitive as oxygen molecules
Originally Posted by serialk11r View Post
Not correct. Nitrogen is a diatomic gas like oxygen with a similar density, its characteristics are extremely similar at these sorts of temperatures.
What causes the tire pressures to swing so much with temp variation is the moisture inside the tire. The reason nitrogen ends up being more stable is the moisture is removed as it is run through the machine or before it gets bottled. It is more dry than naturally compressed air, unless the compressed air is run through a good filter drier. There is moisture in the air contained inside the tire as it is mounted and lots of bead lube are water based. Usually there is a fill & purge procedure recomended to reduce that moisture when using N2.
