THE MOST POWERFUL OUTBOARDS ON THE PLANET | Seven Marine | Home
Look in the technology tab and look at trans, gears and specs. Seems that they have 2 speed lower units for making a shift. Thing about boats is, it's impossible to shift. The water slows you down so fast that by the time you grab your next gear, you've slowed down so much that the engine is stuck in the hole again, only this time it's fighting a taller ratio + drag.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
