As far as extending the pulse width goes, I think there are reasons to not have the duration of the pulse too long. Likely it would be fine, but I thought it would just be easier to have an injector with sufficient capacity.
I have heard estimates anywhere from 15% to 50% increase, but are all throttle body injectors alike and interchangeable? I need to know how to find one that will fit. Can I pull one off an old cavalier or corsica? I don't think I can go to the junk yard or the parts store and say I want an injector with 30% higher flow rate.
I'm aware of the lines issue, and will check that no rubber is in the line. Does anyone know if I will have enough fuel pressure and volume, or will I need a supplemental pump and new regulator?
