Old 10-17-2014, 02:39 AM   #1221 (permalink)
freebeard
thingstodo --
Originally Posted by explainthatstuff!
Page not found! ("404")
In the VW world an input shaft is a standard tool to align the clutch to the flywheel. They're even available in plastic. Not that that would take the torque. If you can cut the shaft you can also make 4 more cuts and leave a 3/4" square stub standing. Pop you torque wrench on that; no welding.
what is a common failure mode for a 3 phase motor that has had too much current?
I was going to say the magic smoke comes out, but thingstodo covered it.
it turned out to be a debugging array index that went out of bounds, and modified a couple variables.
Buffer overrun? Sanitize your inputs or you'll have hackerz in there.
Cyruscosmo, CrazyRick -- Back on page 118, I pointed to this video;
..and it has the most lucid explanation of FOC I've found. Astro looked at it and said it made "a crazy sort of sense".
What do you think?
