Originally Posted by vskid3
K&N filter likely did nothing except maybe raise your wide open throttle power a tiny bit.
Yep, the K&N can potentially shorten the length of the engine & it will not provide any MPG gain. OEM is the way to go for maximum filtration & engine life.
"That said, both the cotton gauze type (K&N) and foam filters (Amsoil & Jackson Racing) showed the same levels of filtration. Both performed poorly compared to the fiberous or paper filters (Napa, Baldwin, and Mazda).
Air Filtration Test - Bob is the Oil Guy - Bob is the Oil Guy
Air Filter Filtration Test - Bob is the Oil Guy - Bob is the Oil Guy
