Old 10-20-2014, 02:11 PM   #15 (permalink)
Grant-53
One can steer by leaning also with less input into to the steering. The narrower bar does mean less torque applied but this is not a liter bike. The front material may need to be stiffer than 4 mm Coroplast. I use 1/2" OD hard nylon tubing hoops for supports. Check out the other projects at craigvetter.com and recumbents.com as well as the threads here.
The Following User Says Thank You to Grant-53 For This Useful Post:
nickec (10-20-2014)
