Originally Posted by AlexanderB
I'm thinking I might drop by a gym and see if they have any worn-out threadmill belts, in my head that seemed like the perfect material to make the lower part of an air dam, and not have it break off on a speedbump or ramp..
Similar to the yellow Corvette (?) above..
If you strike out with the belt material you might check auto parts stores for a medium-density polyurethane foam floor pads.Over here,they come 5-panels per package (610mm X 610mm) for around $15 (US).
I've used the same foam on my truck at least 3-years now with little degradation.
At 75-mph there is no deflection,while if I hit a curb they just bend under until I back away.
Kind of a medium-gray color
