Originally Posted by aerohead
If you strike out with the belt material you might check auto parts stores for a medium-density polyurethane foam floor pads.Over here,they come 5-panels per package (610mm X 610mm) for around $15 (US).
Interesting thought, I have a few lying around - the ones I have are pretty thin though, maybe 6-8mm IIRC? I would have thought it wasn't rigid enough - how thick are the ones on the truck?
