Old 10-21-2014, 03:18 PM   #6 (permalink)
oil pan 4
Want to reduce oil pumping losses? Here is how I would do it.
1 like mechanic said, reduce the relief pressure on the pump.
2 intentionally put an undersized oil pump on the engine and an additional electric oil pump. The electric would run when the engine is cold and below a certain RPM so you don't get near 0 oil pressure at and near idle.
I almost did this with my suburban when I rebuilt the engine, put the undersized factory non-turbo oil pump back on the motor and back it up with and electric but I couldn't find an electric oil pump and filter I liked.
Originally Posted by blownoiler View Post
There is at least one easy gain to be made by fitting a bypass oil filter to your car's oiling system. The small reduction in engine oil pressure experienced when using a bypass filter means less power is required to drive the oil pump, and cleaner engine oil along with possible extended oil/filter changes is a bonus!
How about just put the biggest oil filter that will fit on the oil filter head?
