Old 10-21-2014, 04:46 PM   #8 (permalink)
blownoiler
performance with economy
This is an interesting idea and worth at least poking about I think. I don't think we've delved much into reducing oil pumping losses and I am interested in that subject. Obviously OEMs feel its a worthy area to look at and we're usually doing more than they are.
I had to look up what a bypass oil filtering system was since I'm not super familiar with them. Basically, they take a small amount of the oil being pumped through the filter, and run it through a very fine filter, and return it to the sump.
Obviously this is good for the oil and the engine life by keeping the oil cleaner, but I'm wondering where the fuel efficiency comes from? Are you saying that by running this bypass filter, you're gaining fuel efficiency by decreasing the pressure drop across the filtering system?
The bypass filter effectively drops oil pressure, so the oil pump doesn't have to work as hard. The various bypass filters will no doubt have varying flow rates, they usually have a restrictor in the outlet side of the canister, mine has an outlet hole of approx. 1mm in diameter. The oil pressure in my previous engine dropped maybe 5 psi after fitting the bypass filter, but it is hard to tell exactly because of oil pressure varying with oil temps.
