Yeah I might try that. I want them easily removable to access the air valve . . . . .
But then again, maybe I can just make an air valve extension to go to the inside of the rim instead. Then the only time I would ever need to remove the moons is if I rotated the tires or changed a flat. Hmmmmmmm, has anybody done this?
