Mazda MX6 Day 088 video 021 September 25, 2014
Remove the front wheels to install the complete axles
Remove the passenger side wheel - the blower input is in the way. The axle can't be put int with it in the way, so remove the motor shroud
Insert the paseenger side axle. It does not seal up to the transmission. The transmission adapter plate is in the way. I did not remove enough material from the adapter.
Mazda MX6 Day 088 Video 021 Sept 25 2014 - YouTube
Reason: Got the description wrong - fixed it
