War Wagon
Since there is no marking on that light, I believe that the light is part of an aftermarket installation. I would look under the hood for anything not factory. I presume you will be going into the dash to fix the lighting, so get the wire color and it's cabin exit point so that it can be traced. If it does go to an ECU, try to find which western countries that it was sold in and you might find someone who would print out that page for you in a language that can more easily be translated.
Good luck.
