Originally Posted by MetroMPG
I once drove an 80's Datsun 280z that had a similar set-up from the factory: a "dual spring" accelerator. But I think it was intended more as a "power mode" feature. You had to push fairly hard on the pedal when the 2nd spring came into play.
Hi I tried that in my first few attempts, it was not accurate and I destroyed the accelerator cable
