Originally Posted by Madact
Interesting thought, I have a few lying around - the ones I have are pretty thin though, maybe 6-8mm IIRC? I would have thought it wasn't rigid enough - how thick are the ones on the truck?
Without actually measuring,I'd guess that they're about 13mm.
One side is smooth,the other is a star-plate pattern as you might see with aluminum pickup truck tool boxes which straddle the bed rails.(CRAFTSMAN/TRACTOR SUPPLY)
The nose on the T-100 is 'oval',almost a semicircle in plan-view,which gives a lot of rigidity without any reinforcement.
