Old 07-17-2008, 10:57 PM   #11 (permalink)
Duffman
I disagree about the oil vs coolant. The head will come up to temperature fast because that is where the fire is. Cold oil is more viscous so there is definitely more drag when cold while fuel injection has really solved the cold running problems wrt fuel atomization.
I have seen your other threads and know how handy you are, a stick on pan heater would be a 20-30 min job for you even with pan prep.
