Old 10-22-2014, 09:46 PM   #6 (permalink)
riva2model64
Cam - '94 Toyota Camry LE
Thank you for the replies everyone!
I'll try to take and post pictures tomorrow as it is pitch dark right now.
I only took one "before" picture, so it won't be much of a before/after comparison, sadly.
The wheel style changed slightly, the new wheel is more open.
Tire size did not change, it is the same 205/65/R15 as stock.
I could see a difference in gas mileage if the drag is noticeably higher, but I have a new commute and only have solid MPG data for a different commute/season, so my new MPG results would not be quite Apples-Apples.
I also only have one trial run for highway MPG so I don't know how accurate that would be. For what it's worth though, my fuelly average was 22.4 MPG, and I'll also update my next tank.
The new wheels weigh a few lbs. less
