engine on coasting
My '99 civic used more gas during a trip using eoFc than expected. I suspected that the civic was using gas based on RPMs when the engine was off, and have not used eoFc since that time. Also I think bump starting is not as effective above 40 mph, where the range is on my trips.
Even if bump starting didn't [ lose momentum ] above 40 mph, there's not that much difference between having the engine on or off when coasting in neutral, plus the safety, electrical, efficiency and convenience benefits of having the engine on. Thus, I coast in neutral with the engine still on.
