actually, I didn't even know there was such a thing as a variable pressure switch when I sent the board in. we will have to "blue wire" to an unused pin on the microcontroller. it will need a resistor and cap for a filter, but that would be easy to add. Just one more change for the next revision.
I would love a flywheel. on the back side the post sticks out about 1.1 inches, and is a diameter of 1.125". on tje front is a diameter of 1 inch, and has a key of 0.315". the front is unfortunately where the encoder is too. there is about 1.1" of available post on the front. I should have had the encoder put on the back. but I had the front turned down so an encoder would fit, and didnt even know there was a back until later when it was too late.
