Old 10-25-2014, 12:24 AM   #1263 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
At the moment, I'm using a hall effect throttle, where the middle 15% is "zero", and clockwise rotoates the motor one way, and counter clockwise rotates it the other way. It regens whenever you turn the throttle the opposite way that it wants to turn.
Awesome!
In real life I think we'll use a variable pressure switch on the brake or something. Then, if you press the brake, it regens, and you slow down.
The EVTV guys do something like that. The pressure transducer is 0 - 5V for 0 - 250 psi. But you can also do regen with the accelerator pedal. It gets involved quickly from there. The Generalized Electric Vehicle Control Unit is open source, and their proven method can be reviewed and parts of it used here.
Once it reaches the max regen that you program, if you push harder, then the regular old brake kicks in. That's the idea at least.
That matches the GEVCU pretty well.
I have no way of testing it at the moment. I guess I could rig a brake pedal or something.
Do you have an extra analog input on the PIC available to implement it?
It's just that my motor has no "whatever that's called" when it's really heavy, and hard to slow down.
?Inertia?
I cranked the regen up to 10 amps this morning, and the motor post went from about 1500RPM to 0RPM in about 0.01 second, like it hit a brick wall. Not exactly what we are shooting for in real life.
You might be able to couple the motor to a load, like a generator or a saw mandrel, that would add to your inertia. Might not be worth the effort though. You likely would not see the regen currents for long.
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (10-25-2014)
