Old 10-25-2014, 09:19 PM   #1266 (permalink)
cts_casemod
I find the regen on the throttle quite easy to use. I also find that its more natural to release the throttle and let the car slow down that to place the foot on the brake pedal. Gives a few metets advantage while one switches pedals.
A few thoughts tough:
Regent should be gradually reduced as the vehicle slows down. Too much makes it hard to switch pedals.
A neutral point is good.
If the throttle is used to brake and accelerate, the available resolution goes down. This can make subtle movements a bit rough at low speed. Typically some digital filtering solves the problem. I use a variable that increments by one at low pedal travel and by 5 at full throttle.
The Following 3 Users Say Thank You to cts_casemod For This Useful Post:
e*clipse (10-26-2014), MPaulHolmes (10-25-2014), thingstodo (10-25-2014)
