Originally Posted by Daox
I wouldn't even consider it unless you at least have an alternator delete done already. Also, its an idea that I hadn't heard of talked about here. Instead of spending a few hundred dollars on a pump, this costs under $100 with new parts, and can be salvaged for much less.
I'd actually say it's a great mod to start out with if it's easy to reroute a shorter belt. In dollars per horsepower gained, this has to be one of the cheapest ones!
