Thread: Nissan Leaf
Old 10-26-2014, 05:35 PM   #62 (permalink)
redpoint5
90 day: 38.47 mpg (US)
26.0 miles actual distance + ~2.3% = 26.6 miles indicated on the odometer.
2.3% optimistic seems like quite a large error for the odometer. I wonder if Nissan did this intentionally, or if it's just the tires that are being used.
I don't know about the accuracy of the odometer on the TSX yet, but the speedometer under-reports the speed by about 1%. At 60 MPH indicated, I'm actually doing 59.5 MPH. Of course, I have an analog gauge, so there is some interpretation error.
Originally Posted by Cobb View Post
Be interesting to see if you keep driving in an economy manner or let loose. ..
I know for many evs they either do not have regen braking or the regen is wasted as a surface charge if the vehicle is equipped with lead acid batteries. I believe with the leaf its able to take it all in and allow you to successfully reuse it on your next launch.
When I get an EV, I will drive it as quickly as I believe I can get away with while maintaining safety. At 1/3 the cost of gasoline, I won't care if it cost me an extra $0.05 on my round-trip commute to work. If I find free charging at work, I'll care even less about efficiency, although I will maintain some habits such as coasting and attempting to use regen braking instead of friction braking.
My attitude will completely change when I have range anxiety about making it to my parents house 70 miles away on a dark and cold winter night. 55mph and just enough HVAC to keep the frost off the windows.
