Originally Posted by sqidd
This is how you want to hypermile a corner if you can't take the corner at the same speed as the entry/exit straight. This will give you the best "roll" through the corner.
Constant radius as smooth as possible.
The faster you take the corner the less energy you use.
Yaaay...I am doing it right!
