The air system lives! I still have to determine how long I need the lines and then trim them to length.
I figured out that I don't need the red boots so I'll pull those off before I git the seals installed tomorrow. That will be one less thing to worry about!
I did pump up the shocks to 50psi and I was able to barely push the tongue down to it's lower extreme with my body weight (~170lbs). This is when I figured out that I didn't need the boots as the air pressure pushed the top of the shocks to the top and crushing the boots.
