Originally Posted by Baltothewolf
That, or try to find a D15Z1 (lean burn engine) and swap that in, but good luck finding the VX harness unless you get really lucky. The above engine is definitely your best bet.
[Edit]: I didn't see it comes with a transmission too, that's a steal man, get on it.
Thanks man I did see that late last night, do I need the tranny though?
Also I thought I could not use a d15z1 since its a 16 valve while mine is an 8 valve, also what about the whole vtec connection, i believe mine is SOHC.
