Originally Posted by cannabinoid
Thanks man I did see that late last night, do I need the tranny though?
Also I thought I could not use a d15z1 since its a 16 valve while mine is an 8 valve, also what about the whole vtec connection, i believe mine is SOHC.
You would do a complete engine/wire harness swap. Like I said finding the wire harness and everything probably isn't worth the trouble.
Anyway, about the engine, for 400$? Who cares? That's 200$ for the engine and 200 for the transmission. When yours goes, you will have another right there to slap on!
