Old 10-28-2014, 06:51 PM   #7 (permalink)
Xist
Originally Posted by adam728 View Post
Compare a 4 door Jeep and 2wd, reg cab Ram.
Go to a 4 door 4wd Ram and you can get up over 5700 lbs.
It took me a while just to get that number, I found the Jeep weight right away, although it specified each axle individually, I had not seen that. I am not trying to find the four-door, so I will go off of your numbers. 5,701 pounds is 33.3% heavier and 5,749 lbs is 34.4% heavier.
