Old 10-29-2014, 11:46 AM   #13 (permalink)
jmedia
ecowannabe
Skeeter - '89 Ford Escort LX
Originally Posted by jedi_sol View Post
oooh i wonder if you can retrofit the active grill shutters from the other ford models
Oooo now that is intriguing, I like.
Originally Posted by Goldenstate
Congratulations on the new ride. I notice that your new Ford Focus does not have rear tire spats. My 2014 Fusion SE does not have rear tire spats but has them in front only. My next move to improve mileage on the Fusion is to measure the front spats and carefully make up a set of spats for the rear tires to the same dimensions. In looking at other cars of the same basic size, I will decide just how far ahead of the rear tires to place the custom made spats. Already have some aluminum angle stock that should work well and be strong and light.
I am curious as to what size the front spats are on your 2013 Focus?
Perhaps we can both learn from this new adventure in modding.
Goldenstate
I will have to measure them and get back to you! I'd love to put some spats on, I wish a manufacturer made some.
Originally Posted by Old Mechanic
Actually if the Focus is like my 2011 Fiesta, then it's not really neutral. Coasting in neutral, you can feel the transmission downshifting as you slow down below 45 MPH. The clutch just stays disengaged until you move the shifter back to drive.
You can also calculate the idle fuel consumption by coasting down below 25 MPH and resetting the fuel mileage computation until it drops below 99 MPG. Divide the speed by 99 to get your idle consumption.
Example. If the mileage drops below 99 (max reading) at 20 MPH, then your idle consumption is 20/99, round it off to .2 GPH.
regards
mech
Ya I figured that since it is a DCT, dropping it in neutral would be just like pushing the clutch in and continuing to shift. The cars gotta be ready to go as as soon as you drop it back in gear. I think I am going to avoid consistent shifting in to neutral unless for a large benefit (coasting down the grapevine). In my mind, it puts a lot more stress on the brakes too, slowing down with the car not in gear.
Thanks everyone for the replys!
