Old 10-29-2014, 04:13 PM   #19 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
*Cars don't convert MMBTUs to miles travelled in a directly linear fashion.”
Big Dave says:
If they use the same thermodynamic cycle, that’s a good approximation. The diesel cycle is thermodynamically superior to the Otto cycle, hence they go more miles on a MMBTU.
*What? Still goes down the road with more power than I need.”
Big Dave says:
That’s the advantage of being hypermilers. Average Joe finds this unacceptable.
“Next time don't try to pass off the rubbing alcohol in your medicine cabinet as being the same as fuel-grade ethanol.”
Big Dave says:
Who said anything about rubbing alcohol (44% isopropanol) being anything like fuel grade ethanol.? At the “ethanol” plant the anhydrous (200proof) ethanol is held in a “in bond” tank supervised by a BATF agent until it is denatured by adding 0.5% methanol rendering it undrinkable. Gasoline is not a good denaturant as it can be fractionally distilled off by any competent moonshiner. You simply cannot distill the methanol out of denatured alcohol.
Denatured alcohol used to be used as the solvent for shellac, among other things.
The demand for denatured alcohol as fuel has crowded out all other uses. “Kilz” primer used to be basically white shellac. Hence its excellent covering power. Today the product uses a different resin and mineral spirits (Stoddard solvent) as the solvent.
In this area, E85 sells for about $2.65/gal vs 3.02/gal for RUG (Indiana has no E10 requirement so real RUG is readily available)
E85: $2.65/0.076 MMBTU = $34.87/MMBTU
RUG: $3.02/0.116 MMBTU = $26.03/MMBTU
E85 costs 34% more per MMBTU (taxed motor fuel) than RUG.
I sincerely doubt any claims of any spark-ignition engines being 34% more efficient than another spark-ignition engine.
With only 2/3 the energy of gasoline, ethanol costs more per mile
The heating values from the link are taken from ASTM and API values.
The late great John Lingenfelter built a special E85 LS7 Corvette engine. 13.5: compression and huge injectors and fuel lines to accommodate the less energy-dense E85. 700 HP normally aspirated. To my knowledge it is still in use.
As for the “food vs fuel” argument, the only way biofuel works is if you use desert land and seawater. Algae. I understand that suitable species of algae have been identified. But you also need a source of concentrated CO2 to promote industrial rate plant growth. A coal-fired power plant makes that kind of CO2.
E10 is the very same product reviled in the 1970s as "gasohol."
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
