Originally Posted by COcyclist
Just curious, what pressure are you running in the trailer tire? Is the oscillation less pronounced with a load? My father used to run some pretty low tire pressure in his trailer to cut down on the bouncing, with light loads. We had an old Sears one wheel trailer that he used for many years and thousands of miles.
I'm not sure what the tire pressure is...probably near the maximum pressure...60psi. I'll take a shot at a lower air pressure in the tire and see how much effect it has. Probably like a under inflated basketball...
Just started working on revamping the main body again. I need to clean up the bottom so that there are no air gaps on the bottom. I'm also looking at encapsulating the tire in a shell and see how that will turn out. This will probably use up the remaining Coroplast signs I have left. I might have to start looking at Luan sheets...
