Old 10-29-2014, 06:49 PM   #273 (permalink)
freebeard
It all sounded so simple when you were starting out.
I wonder if a splitter on the front side of the trailer would do any good. Are there any trailers out there now with a front splitter?
Looks like I need to preload a spring (rubber torsion or metal leaf/coil) to handle the additional force. A coilover setup would be nice but it could git pretty pricey and the hitch becoming a hassle to hook/unhook from the hitch receiver with the preload of the coil spring in the coilover setup. I would have to carry around something to compress the spring while hooking up the trailer...like a spring compressor!
There are those motorcycles that have a wedge shape pointed at the bottom of the front tire.
What do you think would happen if you extended that center C-channel back and move the single wheel back even a few inches?
Looking at motorcycle trailers, they tend to have the wheel further back.
Goldwing-styled single wheeled trailer - Page 2
Technical discussion and links in that thread.
aerohead (10-30-2014), BamZipPow (10-29-2014)
