Originally Posted by elhigh
It might not be the clutch. It could be the engine is rotating. A little seepage past the rings, or past the valves, would allow the pressure in the cylinder to bleed off and the car oh so slowly migrates down the drive. At the much higher operating speeds - and with fresh oil getting to them - the rings and valves would be just fine while the engine is running, but just sitting with static pressure on them, they do leak down.
Quarter-million miles. Is that the original engine? I wouldn't be shocked if the rings and valves bled a little pressure over time.
Original engine as far as I know. Previous owner believed the car had a fresh head and head gasket put on at 180k just before he bought the car. Very possible that it is the engine spinning. The car will lock the wheels after moving a couple inches on a hill so you're probably right
