Old 10-30-2014, 07:34 PM   #1 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
Heated tip fuel injectors, Delphi makes em!
Here is a link. Read up!
Delphi Multec 3.5 Heated Tip Port Fuel Injector
Seems it's intended for flex fuel and it doesn't say if it improves combustion for straight gas. At 500*C it ought to though. Smokey would be proud.
This could be an interesting mod once these start showing up in wrecking yards. The next question will likely be what engine changes will take the most advantage of these, like ignition timing, cam timing, compression ratio, intake air temp, etc.
Good design is simple. Getting there isn't.
The Following User Says Thank You to beatr911 For This Useful Post:
Frank Lee (10-30-2014)
