Old 10-31-2014, 06:47 PM   #8 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
For example these ties will work for sure:
Panduit PLT3S-M0
Zipties needed width is 4.5mm to 4.8mm wide.
If you drilled the holes too close to the center of the capsel then you can mount tape to the wheel spokes so the cable ties wont "slide" towards the outer edge.
Needed drill size is 10mm closest is 13/32 in inches and with 25/64 size you only need to rotate the drill slightly to get the plug through the hole.
Hole size is not as important as to get the zipties straigth through the holes.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
