Originally Posted by MazdaMatt
Sounds like an upgrade to my cold towel idea
That was the point of my comment on the other thread.
Slit the seat cushions and sink the tubes in. Very clean.
as long as they don't sink to far I'm sure that it will work well
I'd say exit the tubing under the seat to a "terminal block" of hoses. One block for "in" and one block for "out".
There is some extra space (little loose) in the crease area between the seat and the seat back. I'm planning on doing 4 Manifolds 1 lower out 1 lower in 1 upper out and 1 lower in. basic plan is to have a larger tube (1/2"?) and a series of t's to make a long manifold across the with of the seat.
You could consider using one of those 12V coolers instead of ice water or some fancy paltier thing. Put it in your back seat or trunk. I have grabbed a small 600gph bilge pump from the boating section. I'll let you know how well it moves water through small tubing.
Those electric coolers are pelter based.
Please do let me know how the bilige pumps work for small tubing.
