Old 11-01-2014, 04:50 PM   #8 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.26 mpg (US)
On a car that old, I'd check the cam timing. Then check the ignition timing, not just the idle timing but the timing at higher RPM and the amount of the vacuum advance.
Check for brake drag by checking brake temperature after driving ten miles or so, preferably at highway speed. Coast to a stop, then check each drum with your hand. They should be at ambient temperature. If it's warm, it's dragging.
Manual or automatic transmission? What is the RPM at 60 MPH? What is the available power in top gear at 60 MPH? Will it maintain speed uphill without downshifting? Accelerate uphill without downshifting?
Tape some pieces of yarn to the hood and drive on the highway. If they all point rearward, you are good. If some of them swirl around in circles or point forward, there is room for aerodynamic improvements to the front end.
