Old 11-02-2014, 06:33 PM   #12 (permalink)
gizzardgulpe
Blue Tunic - '13 Honda CR-Z
90 day: 43.69 mpg (US)
Originally Posted by JRMichler View Post
This car is begging for a gear ratio change to get that RPM below 2000. You will lose the "wonderful power", but won't need that power once you get good at DWL.
The gear ratio on the transmission is the same as my wife's Grand Prix, but the difference is in the differential, according to the research I did. The one I probably have is a 4.1:1 and they made a few 3.7:1 differentials. The trick is finding one that is in good working condition. And having the money to pay for it as well.
As for ignition timing, look for a Haynes or Chilton repair manual. You can lose several MPG if the timing is off by only a few degrees.
I used the instructions in the Chilton manual that resulted in such poor timing that I couldn't accelerate into traffic safely. I cannot seem to log in to the state library website to get back to the manual to double-check what I learned, so that'll have to wait for a day or two, but I seem to remember it saying to set the timing to ten degrees at ~600 RPM, and that was just obscene. The car barely ran.
Cam timing is not intended to be adjustable. It changes when timing chains wear.
Does it have a carburetor or fuel injection?
The timing belt is only about 5 or 6 thousand miles old. It is fuel injected.
Originally Posted by Cobb
Plan b, instead of lowering, add an air dam, lawn edge strip bottom of bumper.
The bumper sits about a foot off the ground and I haven't quite figured out how to extend that downward enough to put a wind dam on short of building some kind of framework and manufacturing a new bumper. Any suggestions?
